Synergy sector shaft brace with teraflex
I believe Synergy revised the bracket, i think i got the newer one.
I've always wondered about that reading these threads. I have the TB brackets as well as a full synergy lift and the TB bracket is at least a full inch from the spring. I read that in a couple threads and went out and looked at my rig and was all like .... Whaaat? How is that possible?
For a couple years I ran the Synergy brace (no sector brace) with a TF track bar and it worked fine. The issue was that the Synergy brace's rear gusset would be hit by the Teraflex spring under compression because of its larger diameter. I fixed the interference by cutting off that rear gusset. Worked great after that. I later just went with TF's frame side drop & brace set up and it's still going fine.
Here's mine. It rubbed in 3 spots (red circles) when my 3" synergy springs were compressed to my 3" bumpstops as shown. I ended up cutting the brace along the white line and grinding down the bolt head it rubbed in the top circle. The bolt next to the middle circle was removed and replaced with welds.
