Synergy Jeep JK Front Track Bar Brace and teraflex track bar
Hi All, anyone knows if these two items are compatible? My only concern is the bolt inside the brace which could limit the movement up and down of track bar....
Tks
Mpi
Tks
Mpi
I have this set up, I wanted to use the bracket due to the bigger factory hole in the stock trackbar/axle side bracket. I didn't have a welder to weld a washer on. It would not work with the 3" of lift that I had. I ended up cutting up the bracket. Using the stock hole and the bracket to reinforce the stock bolt hole location. I had to cut the back side out a lot so it would not make contact. If you have 4" of lift or more you may be ok in stock form.
