Switching from lift spacers to springs. Help please
Ok, I went with the RC 2.5" spacer lift on my 2012 2dr rubicon and now wish I would have went with springs instead. So my question is what is the biggest lift springs I can install with my current rear track bar bracket, brake line relocation brackets, exhaust spacers, and such. I would like to go a little higher and i'm not sure what size springs I can get away with safely. Any help would be greatly appreciated. Thanks in advance.
it is a 2.5" rough country spacer lift. Also the front currently sits about 1" lower than the rear because of the winch and bumper.
(sorry I guess I left that out.)
In case it isn't obvious, don't use the spacers with 2.5" springs.
Springs all seem to cost more or less the same, so pick a US-made spring from a brand that has a top reputation for springs quality.
There really isn't anything wrong with the spacer lift other than the fact that I would like to be able to possibly add a small spacer in the front to compensate for the extra weight up front. Also I would like to go a little taller.
Get 2.5" coils to swap out if you don't want to change anything else. Or do more research if you want a taller lift. Over 2.5"-3" you're going to longer brakelines, adj. control arms, track bars, etc....
Your best bet is to get a complete kit with all components that will work together (Teraflex or Rock Krawler are my reccomendations).
