switches for heated seats and power
hello i am try to find out if i buy the 5 gang switch will the heated set switches be able to work it if i install the pads and will it also work the power inverter if i install that also i have a 2016 freedom edition unlimited thank you
check with dealer. I don't believe your new switch (if you could find one) would even have power. It all go through the computer now.
If that were possible, you would have to install the wire that goes from the switch to the heated seat module, if you have one. Then you would need to run wires from the heated seat module to the heated seat elements.
Are you thinking of installing OEM heated seats? Or are you wanting to control aftermarket heated seats with the OEM switch?
Experiment with it to see if the switch can control a relay. If it can, you should be able to do what you want.
