swaying/wandering at high speeds after 2.5 lift
I had a 2.5 Rc suspension lift done yesterday. When I hit about 55 mph and up, I am noticing it gets very flighty and pulls to each side. I did have the rear track bar relocator done and the front adjustable track bar. I will be getting the quick release front sway links in about a week. Any ideas?
or you can go with these... I'm thinking about going to them
Jeep JK Control Arm Relocation
i have a 2.5 TF lift (4dr lift on my 2dr)... but I also have a Daystar 3/4" spacer lift on top of that (closer to 3.5" of total lift). she's a little flighty, but it hasn't bothered me so far.
Yep. Brackets are an option also. But, not a much less $ than new arms.
2.5-3" is right where the JK will start getting the flighty feel. I swear, mine has a slight flightyness bone stock. I bet when I go with a 2.5" lift I will have it bad. Others swear they have no issues at all with stock control arms and 3 1/2" of lift. All depends on the particular Jeep IMO.
When you had the lift installed did they keep the stock sway bar links on the front or just take them off for the time being? Without the sway bar connected you'll get wandering and bad cornering of course. Could also be a caster issue or just a loose bolt. Check all the bolts of the suspension if you can as they should be checked a few hundred miles after install and re-torqued if required.
We have a 5" lift on a 2dr and it doesn't get flighty. It does drive fairly straight for being lifted so much and without having any adjustable control arms. Although arms are next on the list when I get some time to either make them or $ to buy them.
