Swaybar Link Help
Swaybar Link Help
I installed the Teraflex Leveling Kit today, and I think I am having an issue with my drivers side front swaybar link sitting correctly. Not sure if this has to do with my tire seeming to toe out some. We checked the toe in to see and the measurements are good for the rear of the front tires and front of the front tires. Any help wold be appreciated.
Here is the passengers side one
Pic of tire driverside with correct toe in measurements and straightened steering wheel, looks like it is bent slightly outwards though?
Do you think my axle could have shifted when I had my tires and wheels installed? I noticed last week when I was taken pictures of my front grill that my tire look pushed out some?
Hey, unhook your links and push the swaybar over to that side, you might have to loosen where it mounts to the frame.See if that helps. May make it a little better but will probably shift back if your axle is not centered.
Your axle is gonna shift to the driver side when any lift is installed, your tires have nothing to due with the axle shift. Is it driving funky? My front links were like that with my BB. Drove fine.
Yeah no help undoing the links, is there any other way to recenter the axle without having the adjustable front track bar? I was planning on running this leveling kit for 4-6 months until funds allowed for the OME Lift kit w/ JKS adjustable track bars. Driving straight and no pull in either direction, and steering wheel centered.
