Swaybar discos...Teraflex of JKS?
#41
I have the JKS disconnects and have been very pleased. I have the kind that are completely removed and I secure my sway bar up to the frame. I like this set up because the sway bar links stay clean when they are removed. When they are reconnected all you need to do is clean the pins and install the links.
#43
OK I think I read everyone carefully so please do not kill me if already discussed. I have stock JKU sport and plan to do a 2.5 teraflex lift but want discos now (wife has not signed off on lift yet. With all the talk of adjustable JKS I think Teraflex would fit me better but want to confirm. JKS even though adjustable is only 0-2 and 2.5-6 but teraflex 0-2.5. I am correct in saying that to use discos for stock and later using 2.5 BB i would be better off with Teraflex? Thnaks
#44
The nuts just weld behind the holes, try to get them equal on both sides. If I go buy some longer bolts then it'll go thru the disco link and hold the bar in place. As it sits now the bar just rests on the two bolts. When you're done playing just take the 2 bolts out and swing the bar down. Everything has been painted over and appears "factory", after that is a pic from Starr motors today where I flexed the jeep all over with the bar stowed as shown (link removed until I buy the longer bolts) and nothing contacted the bar at all, no noise from the bar either.
#45
I have the jks links and there tuff, I like how the links come off and you can keep them in the truck, also fully greasable and make no noise, my sway bar doesn't move at all when disconnected so I haven't had to tie it down with anything also I have no lift and soon I'm getting a 2.5 rc lift so I wanted the adjustable links
Cheers
Cheers
#46
Cheers
Cheers
#49
My JKS disconnects arrived yesterday. We are going Jeepin in Parker, Az this weekend so I'm going to do the install out there. I'll post some pics when I get back.
