Swaybar Disconnects w/ Bushings?
You can just barely hear them jingle over big bumps but nothing that bothers me. There is maybe 1/16-1/32" of play on one side but I've had no issues. Got like 6-8 pins from tractor supply for $2 and just replace those every couple months or so to keep them tight from taking it on and off. Bottom was enough for me, you would still have to tie the sway bar itself up
The pins always bent. I picked all the hardware up from tractor supply as well. It was definitely a great idea, I just didn't want something that could potentially come lose on the highway.
I use RC's quick disco's. Very similar to TF's in that they come with a frame mount to pin the links up. The Rough Country disco's work really well, quiet, quick easy design, but the low quality heim joints and low grade rubber bushings wear/blow out pretty fast. I'm replacing my adj RC links for Synergy adj links and will be able to keep using the RC frame mounts.
1 Post
okay so i'm gonna try taking the JKS off and bring inside so they can warm up by the fire b4 geasing. maybe this will fix it, just freaking ridiculous IMO
Rancho Disco's
Any thoughts on the Rancho quick disconnects? Rancho RS6753B - RANCHO® Front Links for 07-13 Jeep® Wrangler & Wrangler Unlimited JK with Rubicon Package - Quadratec
