Swaybar Disconnect park bracket issues...
I've installed some swaybar disconnects on my 08 JK Unlimited and when I go to put on the park bracket, I can't because it has to go on the bolt that connects the body to the frame just behind the front grille. When I try to loosen that bolt, the rubber grommet that connects it all just wants to turn, and I cannot get anything on it to hold it. What can I do?
Thanks!!
Thanks!!
Yep they can be a pain. Like said though if you can get some kind of pressure on the bolt or bushing
It will really help. You definitely don't want to break one of those bolts off they are a B_ _ ch to fix.
Using just a regular ratchet wrench is sometimes just to slow of a movement to get the bolt to come loose.
