Swaybar disconnect bypass??
Old 12-15-2012 | 01:22 PM
ronjenx's Avatar
Originally Posted by TheDuff
My 09 would only disconnect in 4lo till I got the trail dash. Now I can disconnect in 4hi
Strange. My '08 will disconnect in 4 hi and lo.
Old 12-15-2012 | 01:49 PM
mpkelley20's Avatar
My '10 disconnect in both high and low. I'm guessing if yours does not, then you have a problem.
Old 12-15-2012 | 03:38 PM
Kenbasstx's Avatar
Yeah when I got it from the stealership the salesmen said you can only use the disconnects in 4low... I've tried in 4high but the light just flashes. I just want to be able to hit a button and use it anytime I want basically. I probably wont be using it in 2wd in an off camber situation. Just want to have the option as stated before.
Old 12-15-2012 | 04:06 PM
ronjenx's Avatar
You may have caught it when it had a torque load on it.
