sway bar and links
sway bar and links
I want to upgrade the sway bar links, front and rear.
Have a 2.5'' lift but don't want quick connects, who sells a really good link and sway bar kit that works with the 2.5 lift?
Any help is appreciated.
The upgrade in the front would be disconnect type. Anything for the back would be basicly what wour taking off. Did you not get any sway bar links when you got the 2.5" lift. The factory sway bars work fine unless you want something like the Currie system, but if you dont even want disco's why would spend the money on upgraded swaybars.
Take the rear sway bar links off and install them on the front, then get a set of JKS adjustable links (adjust them to 2.5" longer than the factory rears) then install them on the rear.
sway bar & links
I did receive links with the lift, but getting some rattles and squeaking, so I am trying to hunt it down.
Stupid question here, but do the quick disco's rattle?
I just installed JKS disco's a week ago and haven't noticed any increased noise from my rig. Keep in mind that I live in TX and have had the windows down for the past week as well so I would have heard any new noises pretty quick.
