Sway bar/disco joint - spring clearance question
Hey guys,
I was looking at my JK the other day and noticed how close the joints where my sway bar discos and sway bar meet...my passenger side has enough clearance between it and my spring that I can easily fit a finger between the two...while my driver side is so close to the spring that I can't even fit a finger.
Can someone explain why this may be happening and or how I can fix this issue? I am running a 4" Pro Comp lift.
Also check to make sure your springs are seated properly. Sometimes they will unseat while disco'd unless you have retaining clips.
A picture would be helpful too.
