Sway bar dash light
qhy would you shut
it off for ever ???? you need this light to indicate if the sway bar is released or not! I dont have the answer for op post but the second answer dosnt sound right !
and who wants to keep getting out to check???????
good luck post the answer if you find it
it off for ever ???? you need this light to indicate if the sway bar is released or not! I dont have the answer for op post but the second answer dosnt sound right ! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=504700"/> and who wants to keep getting out to check??????? good luck post the answer if you find it
I would try using a Procal or see if you can just pull the fuse for it.
