Sway bar causing death wobble?
When I hit a pot hole with one front tire I get short burst of death wobble. It will shake bad for 5 seconds or so and the steering wheel goes back and forth like crazy. Noticed today when I had my sway bar disconnected it rides so smooth and does not wobble at all no matter what kind of hole I hit or how hard. Could this be caused by something being wrong with my sway bar???
After the lift, with stock sway bar links, I had death wobble...
Then I changed it for JKS quick disco, with the right size, putting the sway bar into -5 to +5 degrees, where 0 is parallel to chassis, the death wobble was solved!!
So check the sway bar angle with it not disconnected...
Well disconnecting the sway bar worked for a little bit. Anyone have any idea what I need to look at to fix this. I have a rustys 3.25 on my two door with gave me just over 4in. I have track bar brackets and extended sway bar links. I was thinking about getting a adj front track bar, new steering stabilizer and front lower adj control arms. Would this prob fix it or could it be something like u joints or ball joints????
