Sway bar angle.
Old 12-09-2014 | 02:47 PM
Learo2000GT's Avatar
Default Sway bar angle.
Have jkur 2013 rk2.5 flex with 35s. I was trying to set up my front seat bar so there isn't chance of turning it into pretsle. Flexes it out and set it up. Sway bar is at 20 degrees plus. Questions. Does the angle effect handling like woundering, tq steer so on. Also I am using the RK links with disconnect pins.
Old 12-09-2014 | 07:43 PM
TheDirtman's Avatar
Best to set it up flat or pointing slighly up. It should not affect handeling like you describe. It only actually does something when you are arrticulation the suspension and helps to minimize body roll in high speed turns.
