suspension upgrades ?help?
so im getting ready to install my 2.5 inch lift that comes with 4 2.5" spacers, brake line brackets, and shock brackets. i also have some jks swaybar disco's for this setup.
my question being what other suspension parts SHOULD i change, and what ones would make for a better ride without breaking the bank? part? and brand? i was thinking new shocks but what ones, and do i get ones for the lift and toss the brackets?
im a weekend worrior but my jeep is also my dd
thanks in advance.
tony
thanks in advance.
tony
I have played around with my suspension quite a bit and in my opinion at 2.5 and under you do not need much else, i would buy some high quality shocks like OME or Beilsten.
at 3" you start needing track bars and or brackets/ cam bolts or control arms.
at over 3.5 a whole lot of additional parts if you want the road handling to be anything like stock.
I just added AEV control arm drop brackets, what an improvement in ride, doing flip drag link this weekend and removing a frame mounted rear track bar bracket in favor of an axle mounted teraflex bracket, all to help with stearing and road handling.
I am just over 3.5"
I am just over 3.5"
spacers and the reason i went with a 2.5 was that it was my understand that i did not need much changed out, it is also my understanding that i can get alot better ride then stock by changing out my shocks?
so if im correct with that thinking? do i use the shock spacers with stock hight shocks or go to a set ment for a 2.5 inch lift?
also will the extra half inch keep me from popping my flares or do i need some bump stops and if what size, brand, kind??????
rear links?
ill be running the 2.5" lift and 33s so how tall of bump stops am i looking at? 2.5"s right?
also
a good source told me ome nitrochargers would be my best bang for my buck, comments? anyone running them?
also
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
rear links?
![Brows](https://www.jk-forum.com/forums/images/smilies/brows.gif)
Just depends. You can get by with less if you chop your flares or have shorter tires.
![Bleh](https://www.jk-forum.com/forums/images/smilies/bleh.gif)
im working on learning how to post pics, dont know why its so hard for me. definitly doing something wrong there![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
i have jks qd for the front but ill look into longer ones for the rear
as for the bump stops i think ill go the 2.5, i like the look of the flats but im thinken it will look funny with this setup
![Sigh](https://www.jk-forum.com/forums/images/smilies/sigh.gif)
[QUOTE=fattony21;2044192]im working on learning how to post pics, dont know why its so hard for me. definitly doing something wrong there![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
/QUOTE]
The stickies up top
https://www.jk-forum.com/forums/foru...-Forum-Support
/QUOTE]
The stickies up top
