Suspension upgrade and suggestions
I want to possibly upgrade my suspension system but I'm not sure exactly what will be needed. I want a 3.5" lift and my jeep is a DD with almost no offroading so I probably won't need drive shafts.
Right now I have a teraflex 2.5" lift and just swapped out my shocks for some bilsteins 5100 which I'm planning on keeping. Other suspension components I already have is as follows;
New 5100's as mentioned
AEV geometry correction brackets
front lower adjustable arms (teraflex)
adjustable front trackbar (teraflex)
So what do I need to get me on my way to a 3.5" lift
Are the shocks you bought going to be long enough for the bigger lift? You may want to measure those shocks and make sure that they'll work for you. Other than that you should be okay. I hope this helps!
-Zach
