suspension upgrade help
2011 jku, I have a 3.25 RC lift with TF front lower arms, jks adjustable trac bar. I don't have anything good to say about current set up. I just ordered RK 3.5 coils and bilstein shocks. Also ordered rear wedges for coils. Current kit has bump stops and sway bar links. Do I need anything else? Thanks for the help
I doubt you are going to see much of an improvement by ordering RK coils and bilstein shocks. The poor stering geometry and lack of adjustable control arms is generally what leads to a poor ride in the RC lifts. YOu addressed neither of these issues.
Are you running a raised rear track bar bracket? You will want one that is roughly 4" taller then stock. Once you install those new 3.5" coils see how things feel, but you should have some light steering feel and likely some bump steer. A drag link flip will help with steering as well as a stronger tie rod. This will require a front raised track bar bracket.
What psi are you running your tires at?
