Suspension Lift "Actual Height Gain" database
Old 03-10-2009 | 10:54 AM
noot's Avatar
Post Suspension Lift "Actual Height Gain" database
The DB has started. Submit your ACTUAL HEIGHT GAINED from your lift. Include the following info:
-Lift brand/model
-Actual height gained (front and rear), measure it properly please!
-Applicable jeep specs (2dr/4dr, hard/soft top, bumpers, spare tire, cargo, etc).
Measuring technique:
Be smart, don't include height gain as a result of larger tires, etc. I think most people do before/after measurements from ground to fender.
Attached is a zip file (can't attach XLS files) containing an Excel spreadsheet. You may sort/rearrange the data however you'd like. It's currently sorted by advertised lift, then actual lift.
File Type: zip
Old 03-10-2009 | 10:57 AM
joey2times's Avatar
I love this idea.
Old 03-10-2009 | 11:03 AM
JKRockStomper's Avatar
Have to add 2dr or 4 dr, hardtop or soft top.
Old 03-10-2009 | 11:06 AM
sgalway's Avatar
4dr with hardtop, 100lbs roof rack, and AEV front bumper...
Black Diamond 3" short arm netted me 3.75"
Old 03-10-2009 | 11:08 AM
mad_philosopher's Avatar
Like this idea, i can not contribute yet, at least not for couple weeks until i get my lift
Old 03-10-2009 | 11:09 AM
bigbluejk's Avatar
too bad you cannot add the info to the photos that the guy has of all the diff lifts. Unless people put the brand and height in the tiitle it will be too hard to search through them all if you get a bunch.
like I would put Teraflex 3" 2dr HT in the title
then put the specs in the message.
Old 03-10-2009 | 11:42 AM
noot's Avatar
Perhaps I'll just attach an Excel spreadsheet. That way, they can be sorted by anything (brand, actual height, advertised height, etc)
Thoughts?
Old 03-10-2009 | 03:37 PM
jkJason's Avatar
Lets make sure the measurements take into account changes in tire size. I've noticed some people reporting ~4.5 inches of lift from a 3 inch coil but didn't mention they upgraded from 32's to 35's. (I've noticed the tire difference in their before and after shots). I know some lifts do give you more lift than advertised so I'm not bashing anybody, just saying I'v seen the mistake before.
Old 03-10-2009 | 03:43 PM
bigbluejk's Avatar
If it is the teraflex lift... dont be surprised if that is not including the tire size. I measured my 3" right after install and got more than 4". It may have settled a little by now.
Old 03-10-2009 | 03:56 PM
1JK's*'s Avatar
Teraflex 2.5" coil on a Rubicon Unlimited Soft top with stock bumpers and rock rails netted me 3.25" in the front and exactly 3" in the back.
Quick Reply: Suspension Lift "Actual Height Gain" database
