Suspension advice
I lifted my jeep 5" and it rode fine in Virginia. The highways were smooth and I could adjust to the stiff suspension. I recently relocated to Puerto Rico for two years and have been driving my JK around. The roads are not maintained here with hole after pot hole after ditch, etc. driving between 45-70 mph are unbearable with the Jeep actually loosening suspension parts.
Is there a way to smooth out a lifted jeep on the highway? I tried airing down my tires like some suggested however that caused death wobble (Maybe its only certain tire manufactures). Could long control arms make a difference? Any suggestions greatly appreciated
Going with a long arm will deffinatly soften the ride for the highway use by allowing more articulation of the suspension. Also the off road capabilities are reall nice too if you end up looking for long arms check clayton offroad or teraflex they both have nice setups. Also getting a self adjustable shock, the cost is a little high on most but you can custom tume your ride.
Sponsoring Manufacturer
A quality long arm kit will make a nice improvement in your ride quality. Any long arm kit alone will flatten out the angles. So also look into the type of bushings they use, the type of flex joints, how long these actual long arms are and their mounting points.
We sell an upgrade kit, and also a front half only. The complete system works best front and rear, onroad, offroad, climbing ability and flex. But as far as bang for your buck you can start with the front, and you will see a huge onroad improvement.
JK Long Arm Upgrade Kit
JK Front Long Arm Upgrade Kit
Good luck.
Adam
Clayton Off Road Inc.
Good luck.
Adam
Thanks for the suggestions. I have all skyjacker but if a different manufactures shocks and long arms will make a difference in ride quality I'm all for it.
