Superlift help
Old 12-12-2008, 02:52 PM
  #71
kntr's Avatar
Ok here it is. Im running 5 degrees of caster.
The adjustable arms will be going in soon. How much caster should I be looking at with the new arms?
Old 12-12-2008, 02:56 PM
  #72
JK-Forum Founder
wayoflife's Avatar
+4.2° is what you have factory. i typically recommend that you go to about +6°. if your front driveshaft can handle more without vibrating at higher speeds, i'd go +7°. of course, you really should still try and address your trackbar/draglink. getting them flatter will make a difference as well. also, with your 37's, try to make sure that you are running them at about 26-28 psi. that'll help some too.
Old 12-12-2008, 03:00 PM
  #73
kntr's Avatar
High Steer Kit should be here next week to address the other issues
Old 12-12-2008, 03:43 PM
  #74
JulietKilo's Avatar
Run the control arms at 23 1/4" with stock upper control arms will give you about 6-7 degrees of caster. WOL gave me this measurement and it was perfect. My Jeep drives true and no vibes!
Old 12-12-2008, 05:06 PM
  #75
kntr's Avatar
Teraflex says 24" drivers and 24 1/8" on passenger.
Old 12-12-2008, 05:11 PM
  #76
JulietKilo's Avatar
That is if you have adjustable uppers. If its stock use 23 1/4" on both sides. That is what I did and got a 6-7 degree caster. Its hard to tell since the degree marks are so close but its right between 6-7.
Old 12-12-2008, 07:30 PM
  #77
JKMoses's Avatar
Kntr, you have Superlift 4” and 37”, but did you mod your drive shafts?
Old 12-12-2008, 07:49 PM
  #78
kntr's Avatar
No, I still run the stock drivelines. Ive had the lift on for 6000 miles. I plan on a new front driveline in the future
Old 12-13-2008, 07:18 AM
  #79
JulietKilo's Avatar
Same here, driveshafts are not needed right away if ever. Depends on what you want to do. If I break then I will fix it stronger but the driveshafts have been really good to me on and off road!
Old 12-13-2008, 07:27 AM
  #80
Dr.McNinja's Avatar
Is that hole to hole straight line measurement, or something else?
Mine get here in 4 days, hopefully the Curries work out well for me.
Quick Reply: Superlift help
