Superlift help
#72
JK-Forum Founder
+4.2° is what you have factory. i typically recommend that you go to about +6°. if your front driveshaft can handle more without vibrating at higher speeds, i'd go +7°. of course, you really should still try and address your trackbar/draglink. getting them flatter will make a difference as well. also, with your 37's, try to make sure that you are running them at about 26-28 psi. that'll help some too.
#74
1 Post
Run the control arms at 23 1/4" with stock upper control arms will give you about 6-7 degrees of caster. WOL gave me this measurement and it was perfect. My Jeep drives true and no vibes!
#78
#79
1 Post
Same here, driveshafts are not needed right away if ever. Depends on what you want to do. If I break then I will fix it stronger but the driveshafts have been really good to me on and off road!
#80
Mine get here in 4 days, hopefully the Curries work out well for me.
