Superlift help
#141
The jam nuts on the adjustable arms are huge. I just used a tongue and groove adjustable wrench. It isn't like you need to tighten them to spec or anything, because if the entire apparatus rotates, you have much bigger problems than a loose nut.
#142
X2, I'd love to go to Montana! My wife and I have always talked about going. Must have been something about it in all those country songs I listened to when I was a kid. Ah, maybe one day. I got a BIGGASS 2 1/2 in crecent from my dad, no more worries about tightening big nuts now! Pipe wrench worked before that, I think that's the simple name for a tongue and groove. A big crecent will come in handy for adj trk bar jam nuts and bolts also.
#143
GONETOSHOOT dropped of a pipe wrench and a crecent. The cresent wasnt big enough. I turned the arms in one full turn today. It took about 15 minutes. I just used a rachet strap to pull the axle back to get the bolts to go back through. Super easy.
Would it be a good idea to have the alignement checked again? When you change caster doesnt it affect toe also?
#144
#146
I did have to fix the boot on the driveline. The boot had pulled out from under the clamp. I took the clamp off and pulled the boot back straight and then put the clamp back on. It should be good to go for awhile. Ill have to watch it.
I might take it to the alignment shop in a month or so. Ill tell them to not mess with the castor and I want to watch them do the alignment.
#147
1 Post
I havent gone for a test drive yet. We are having a crazy snow storm right now and the roads are all snow packed. I wouldn't be able to tell if the vibe was gone or not. It was barely there before.
