Superlift???
Superlift???
What are your experiences with Superlift lifts? How is the quality? I am looking at exchanging my 2.5'' Teraflex coil lift for the 4" Superlift with shocks. I plan on running 35" tires on a 2012 4door Rubi.
I have a 2012 JK 4 door. When I purchased it the jeep dealer said that unless I had them install the lift it would void my suspension warranty. So I had them do it and the kit they used on it was a superlift 4 inch kit. It seems just fine, the shocks are Bilstine.
I have a 4" superlift or had a 4" superlift , the only thing left is the springs the shocks are crap , but I have been happy with the springs no sag in over 5 years
The superlift basic shocks are junk. Get Bilsteins if you get the kit. The basic kit comes with cambolts for adjusting castor by slotting your control arms. Search this on here and decide for yourself if this is something you wish to do. The springs to ride good but don't hold weight very well. The adj tracbar that comes with the kit is junk and has come apart on people, came apart at the joint on a guy I sold mine to a month or to after he had it. Kit was only a little over a year old. I don't know if they have addressed this issue or not with a better TB/joint. The bumpstops are a hard poly material, it'll crack and fall apart after a year or so. Rear trackbar bracket has been improved upon I do believe, it should be welded on for reinforcement. I changed my Superlift out for a 4in Teraflex.
Good to know. Thanks for the advice. I would get it through the dealer if it wasn't marked up 3 times as much. I believe they quoted me 4400 bucks for the long arm kit.
So in short the rear needs to welded on or get a different bracket , I just read what you posted a long arm superlift if that is so run run far
