Superchips question
Superchips question
i bought and installed the superchips flash programer on my jeep. i was keeping the programer in my glove box. the only night i didnt lock my jeep, someone decided to take that among other things. so currently my jeep is set on the performance mode. can i buy a new one and use it or am i just stuck now?
I have the Hyper Tech programmer installed on my Jk. I took the jeep to the dealer for a recall and when I got it back it was no longer programmed and had to reinstall. With that said, maybe you can take it to a dealer and have them reset it.
Sponsoring Vendor
ORW Representative
ORW Representative
unfortunately, the way the flash programmers work, is they pull the stock program and "save" it in the programmer itself. It gets swapped for the "performance tune". So, if the tuner disappears or is stolen, your stock program is out there running around with it.
The only solution if you ever want to return to stock, would be to have a local dealership reflash the pcm back to stock, then you could start over with a new tuner if you wanted. Sorry I couldn't give you better news....
justin
justin
justin
justin
I just upgraded to a Ripp supercharger and now my super chips unit is no longer needed, if I sell it will it work for the new owner?
Sponsoring Vendor
ORW Representative
ORW Representative
Looks like someone already answered, but yes it will. you just have to pull out the programming and return yours back to stock. Then, someone else can use the programmer.
