superchips
superchips
I bought the superchips programmer, my question is this:
I have an 07'jku Sahara, bought it used and have no clue what gears it has, the programmer said I have 4.10's...do I or how do I tell what gears I have
You can jack up the rear axle and spin the tires and watch the pinion yoke. The yoke should spin about 4 times to the tires doing 1 complete rotation. Their also may be a tag on the rear axle that will say.
I believe that in 07 the 4:10 ratio came with the trailer tow pkg. the programmer will break down vin when you plug it in and i believe that it will set your stock ratio, but it also has option to change ratio if you change gears from factory.
I read the same things one several other threads and verified the information by getting the number off the diff cover. My 2007 has a tow package and does have 4:10. Dana 30 front and Dana 44 rear.
