superchip--transmission shift points
ok--i set the advanced tune to 93 and i really like the way my jeep drives..i'm still confused about how to change the shift points. can someone elxplain?
there's generic shift up and down, but then they list shift 1, 2, 3, etc. what does that do? and what is WOT?
are there simple transmission adjustments? the explainer on the SC chat forum is kinda confusing. help
thanks
steve
thanks
steve
It is somewhat complicated, and is best to find someone with the same year Jeep as yours that is set up somewhat the same and use their settings as a baseline. The 1,2, and 3 allow you to change from default how it shifts. Either by speed, RPM, or throttle position. You can change not only where it upshifts, but also how it downshifts. You do have to be careful that he shift schedule between upshift and downshift don't cross, or you could have big problems
