Superchip Flashpaq (need jeep to stay in 4th gear on freeway)
So i lifted my 2009 jk. I put a 4inch lift on it with 35inch tires. It is still running the stock gearing and i would like the car to stay in higher gears. I will be going at a constant speed and it will just randomly drop a gear. I was told that the superchip would make a big difference with how the car shifts. Im kinda sick of getting 12 mpg. Any help would be awesome. Thanks!
Although very costly a re-gearing will bring you back up to speed and MPGs too.
A superchip will help you by giving a bit more power and mpgs. Like the other person said you probably need to fix your speedometer too. If you havent fixed your speedo, you wont be able to calculate your mpgs correctly. But with 35s you will probably need the regear
Originally Posted by jimk403
Flashpaq won't fix that, nor will any other tuner. Only thing that will is re-gearing.
