Super charging your rig
I want to take this time to make you all aware that if you decide to Supercharge your rig be fully aware that there is a small disclaimer from the mfg. (Vortec in my case) that it is NOT covered under warranty if you drive it in conditions under 32 degrees f. After spending 5,700.00 on a complete unit just over a year ago it is now under repair and it is not good and the worst part of all I store my Jeep during the winter months but apparently when I started it in late March on a 40 degree day it burned up.
Has anyone else experienced this or do I just have bad luck. I have left the distributor or supplier of the unit out of this email because it is not their fault but I do think they should be making it clear to all buyers that the disclaimer is there so be aware.
Michigan man
Michigan man
I'm interested to know the reason as well. I know that there is a supercharged JK in my city and we spend half the year with temperatures below freezing.
I'm told all units by all manufacturers have the disclaimer but that is just heresay because I did not go and look at all the sites but what I recommend is you do your homework before you buy one. If it is a vortec unit which is very popular then go to their site and read up on the warranty and disclaimer section. I do not want any of you to invest this kind of money if you plan to drive it all year around.
I say anyone that survived the winter with their unit either got lucky of their particular unit is set up (oil lines) to tolerate the cold. As I said if you have a unit or will be buying a unit go o the mfg. of the blower unit itself and read up. In my case the unit "Apparently" came with a disclaimer but I sure didn't see it and if I had I would have not done it.
You stored your unit and it fried. These guys continued driving through the winter, getting fresh lube pumping through there. Seems like you just have an issue from it setting more than the cold itself. Some turbo designs are like that as well. They caution to not store the vehicle too long for the same reason.
