Suggestions for real roll cage (not bolt-in)
We would recommend the Synergy (poly) cage. Other than this we would recommend having a custom cage built for you. The River Raider cage mentioned attaches to the factory cage which does not offer a huge amount of protection. The Synergy cage completely removes the factory cage and goes to the frame and not the body. In a violent enough roll over it is possible that the factory cage can either collapse or puncture through the body panels it is mounted to.
Both piggyback off the factory cage. For a 2 door, they both keep the 2.25x.188 B-C hoops, the 1x3x.125 B-pillar cross bar, and the 1.75x.188 A(Windshield)-B Header. Both also add A and C pillar cross bars, A pillars, Dash Spreader, and front and rear overhad bars. The kits come with assorted 1.75x.188 or 1.5x.188 bars depending on location.
The major difference is the mounting. River Raider bolts the A pillar to the firewall under the dash. Synergy goes through the dash and through the floor and ties to the frame at the A pillar, and also at the B pillar on the 4 door.
The only purchasable kit that fully replaces the cage is the Genright 4 door only kit that is supposed to hit production in July. It's a 100% weld in replacement, but does not tie to the fram at any location.
Having said that, I'm currently working on installing the synergy. The one change I'm making is I've removed the factory B pillar cross bar and replaced it with a fully welded 2x4x.188 wall cross bar that ties the factory B-C and A-B bars together.
I'll get a cage before I go. Saving the one huge favor for getting you to be the guide when I go.
The house isn't done yet? Did you have those guys carving boards by hand out of timber sourced from your lot?!
I'll trade you. The city won't let me expand my garage, or build a second one...
I have not even applied for a permit yet, I can't seem to get the plans out of engineering so I can apply. Been almost 3 months in engeneeing on a 2700 sf house
