Suggestions fix my Rollover Feeling on JKU 5.5 Lift
#31
You said 2'' bumps is plenty. That's not exactly true. If we want to break out grinders cutting torches welders and structurly alter the platform and make something fit that's something different than saying 2'' bumps is plenty. That's like saying you can easily pull 500 hp. Out of the jk and then tossing in the caveat later that you need to swap in a V8.
#32
Nobody is arguing you can't cut grind and weld your way to just about anything but you do that because for instance 2'' bumpstops was not plenty. Anyway that's probably enough of a hijack at this point. Let's all go check our grinding wheels and metal cutting blades.
