Suggestions fix my Rollover Feeling on JKU 5.5 Lift
Old 10-21-2016, 04:16 PM
  #31
Chuck-The-Ripper's Avatar
Originally Posted by rsbmg
You said 2'' bumps is plenty. That's not exactly true. If we want to break out grinders cutting torches welders and structurly alter the platform and make something fit that's something different than saying 2'' bumps is plenty. That's like saying you can easily pull 500 hp. Out of the jk and then tossing in the caveat later that you need to swap in a V8.
There's nothing structural about a the last 1" of a pinch seam, guy. 1" bump stops, 37s, and 2.5" lift. No rubbing. SLIGHT trimming, also frame notched but that's because of my drag link flip which is not the subject.
ID:	659453   Click image for larger version
ID:	659455   Click image for larger version
Old 10-21-2016, 04:41 PM
  #32
rsbmg's Avatar
Nobody is arguing you can't cut grind and weld your way to just about anything but you do that because for instance 2'' bumpstops was not plenty. Anyway that's probably enough of a hijack at this point. Let's all go check our grinding wheels and metal cutting blades.
Quick Reply: Suggestions fix my Rollover Feeling on JKU 5.5 Lift
