Suggestions fix my Rollover Feeling on JKU 5.5 Lift
Find an alignment shop. Some shops will check it for free, they'll just throw it on the rack and print the 'before' numbers without actually changing anything. Then tell us what the caster and toe are. Could be as simple as needing to re-adjust the control arms. (or it could be that you're so tall that adding caster induces driveshaft vibes. )
45 psi? Look for more opinions, but it seems much more common for folks on here to run 37's down in the 25-30 psi range. Worth a shot to drop the pressure and see if the handling changes. And I seem to recall several people mentioning a radial pull from those toyo's?
Did you verify if you have the drop pitman installed, or the stock pitman? One way to check the angles is to take a wide angle pic of the front axle that shows both ends of the trackbar and draglink in the same pic. Then open it in Paint or whatever and draw straight lines between the mounting points on both bars. Much easier to see how parallel they are that way.
Never ever again take advice from whoever put that lift on, or convinced you to put that lift on. Check out this thread by Dirtman ...
https://www.jk-forum.com/forums/modi...-lifts-288269/
