Stuck between lifts..Please help decide!
#31
Argueing aside, I would strongly dissuade you from doing cambolts, even as a temporary solution, it's going to cause more headache than it's worth. You can run a 3" TF lift without arms and still be decently drivable until you can afford lower arms.
#32
Back to our regularly scheduled program...
The TF front trackbar is an awesome design. It has a turn-buckle in the middle. That means it takes about 1 minutes to adjust the front axle. And you can do it with the jeep on the ground. Just hop under, loosen two clamp bolts and turn the turn buckle, tighten the clamp bolts. No jacking, no messing around with ratchet straps to move the axle, no having friends push on the body, etc.
#33
Things sould be explained with out being an ass. Im not the type to engage in a flame war and not scared of key board bullies.
Anyway, F'it!
Im out and final post on this thread. Thanks for everyones input and yes that includes you "Bigbluejk".
Anyway, F'it!
