Stuck between lifts..Please help decide!
#21
That RE lift uses cam bolts to adjust driveline angles. Cam bolts are a cheap way to fix the angles and break easily. However at least it addresses the problem. I'd get the TF kit but with some adjustable arms. OR get the RE kit and use the cam bolts tell you have the dough to buy adjustable control arms to replace the cam bolts.
#22
Me too!
I too am stuck between lifts. Personally I think this decision is one of the hardest I have ever had to make. I am also leaning towards the TF 3" w/ Fullflex arms or possibly even TF 4".
However, I am also considering the OME HD lift from Northridge w/ front & rear adj. trackbars.
I am going to run 35" KM2's or Toyo M/T for now as I have a Sahara w/ auto &3.73 gears' but was thinking of going w/ the TF 4" as I could upgrade to 37's after I re-gear.
Sorry don't mean to hi-jack the thread but it sounds like the same issue.
Your opinions?
Your opinions?
#23
It is obvious that you don;t believe anything I have typed in here, but do some searching in this forum and all over the internet. The cambolt install is a big mistake. That is why you don't see most real suspension systems coming with them. They come with adj. arms instead. If you look at companies like superlift, skyjacker, rough country, RE, whatever... they are the ones with cambolts. Look at companies like Teraflex, currie, clayton, etc.. They either come with adj. control arms or nothing at all. If you are smart (I kinda doubt you are after asking for advice from people and listening to none) you should just leave your control arms alone until you can afford the adj. lower arms. But if you want a hacked up re-welded retarded arm then you are on the right track. You should at least ask a couple guys in the forum that used cambolts what they think of them. Best of luck... I am not responding in your thread again. Pointless, waste of time.
#24
I wasn't aware of having to cut your brackets, thats worse than I thought. I don't think RE offers adjustable short arms either. So what advantage does the RE 3.5 short arm have over TF? This is why I chose tf 3'' with tf arms.
#25
#26
ya, the control arm brackets have got to be cut so that the cam bolts can move. instead of the control arm bracket having a hole in it that the bolt goes through, it will have a slit so that the cam bolt can move back and fort a little. It allows for less than half an inch of adjustment, and is only kept in place by a nut and the cam pressing against a notch in the bracket. That is why they come loose and move around. You are a smart guy getting the arms. I wouldn't want to have to get my brackets rewelded and hope that johnny welder gets the washers lined up perfectly. The only benefit I see for the RE kit is that it is cheap.
#27
If you install cambolts you are retarded. Everyone that has done them regrets it. You know that your control arm bracket has to be cut for the cambolts to work, right? Then when you realize that the caster sucks and your Jeep is all over the road, and your cambolts are pushed all the way out, you are going to have to get metal washers welded into the control arm brackets.
I know that the TF kit is a great kit but maybe thats just not what i want to go with. Its my JK, my taste, my money, and my ways. You should really try the "preview post" button and read what you write before you post so check yourself and stop being a doushebag!!
#28
You dont have to be a D!CK about it!! If i knew what i was doing then i wouldnt have asked the question. What makes you think that im not listening to peoples suggestions? Do you think that i am basing my decision on just these responces? You should do some reading on other threads as well or maybe im geting PMs from other people.
#29
I wrote a whole bunch of stuff, but F-it. You are still gonna post the same dumb questions all over the forum. There is nothing wrong with RE or the kit you bought. I was just trying to warn you that if you use those cam-bolts you are gonna be sorry. But like 12 other people in the 6 other threads you posted these questions in said the same thing. Ya, I am a dick on here, but I can be a real asshole in real life. So piss off cheesedick and just know you will remember this post when you are at the shop paying 2 or 3 labor hours getting your control arm brackets fixed.
