Strongest front track bar ???
RocKrawler
I have a RocKrawler which is very beefy - but the new Teraflex design with the knuckle you loosen and spin to adjust is lot easier to fine tune than the Rockrawler design you have to detach and adjust.
I see they've made the same changes to the rear trackbar now too! guess i bought too early.
How come on the Northridge website it says the Teraflex rear trackbar is designed to work with a new trackbar bracket, but on here you guys are saying it works on a stock JK no new bracket required. Are there two different types?
David
You can use the trackbar without a trackbar bracket and you can use a trackbar bracket without a trackbar. However, a trackbar will only recenter the axle not correct the rear geometry. On a 2.5" or less you can get away without using either or just a trackbar or just the trackbar bracket. With taller kits it's better to have a axle mounted trackbar bracket (fixes geometry) and a rear adjustable trackbar to recenter rear axle perfectly.
i have teh TF 2.5" coil/shock.. came with rear trackbar bracket.. should I get the front trackbar or rear first?
David, what are these runnin ($$), nowadays??
219.95 And Free Shipping
David
