Stronger headbolts? 3.8l
Old 02-19-2016 | 11:21 AM
Jasoncinpean's Avatar
Originally Posted by TOTL Innovations
Prodigy Turbo offered upgraded head studs for their higher boost version if I recall correctly so you probably wont need to get custom studs made.
Thanks all call
Old 02-19-2016 | 11:27 AM
Originally Posted by Jasoncinpean
Thanks all call
Dang 700 bucks for the bolts.... Guess I should have linexed my jeep tub at the same time as fixing my blown head
Old 02-19-2016 | 12:18 PM
Grant09's Avatar
My Jeep doesn't have a turbo or supercharger, but I have had experience with turbocharged vehicles in the past so here's my 2 cents:
If it were me I'd stick with the OEM head bolts and gasket. If you run into another over-boost incident you want those to be the "weak link" in the system. They're cheaper to replace than heads or pistons. If you don't have anymore over-boost issues, then you should be fine and didn't need to spend the extra money anyway.
Old 02-19-2016 | 01:37 PM
Originally Posted by Grant09
My Jeep doesn't have a turbo or supercharger, but I have had experience with turbocharged vehicles in the past so here's my 2 cents: If it were me I'd stick with the OEM head bolts and gasket. If you run into another over-boost incident you want those to be the "weak link" in the system. They're cheaper to replace than heads or pistons. If you don't have anymore over-boost issues, then you should be fine and didn't need to spend the extra money anyway.
Ok thanks bro yeah before I was really hitting it hard trying to see how much boost I could squeeze out now I just want to repair it and own the trails again.
Old 02-19-2016 | 08:52 PM
Just in case anyone ever runs into this thread, I spoke with arp and will get a quote for custom studs. I will let you guys know how much cheaper it is to buy strait from the source.
Old 02-20-2016 | 05:55 AM
T&ERun's Avatar
Awesome. Let us know.
Old 02-20-2016 | 06:01 AM
T&ERun's Avatar
That is flat out stupid. Falls in line with all of their other over priced kits.
Old 02-20-2016 | 07:41 AM
Honestly, taking the engine apart Tuesday and than will be contacting arp. They said they will get back to me same day after I fill out some page in there catalog
Quick Reply: Stronger headbolts? 3.8l
