Stronger headbolts? 3.8l
Old 02-18-2016, 02:35 PM
Jasoncinpean's Avatar
Default Stronger headbolts? 3.8l
Hi guys have a 3.8l wrangler unlimited blew my head gasket. Does someone make some stronger head bolts? Cannot find anything! Looked high and low other shops did too. Anyone have luck? Thanks
Old 02-18-2016, 03:23 PM
Maertz's Avatar
weld the heads on?
Old 02-18-2016, 04:16 PM
Riflejk's Avatar
Arp... Stage 8... H1...all fastener company's. They can make anything, just may not have pre-made kits to order.
Old 02-18-2016, 04:30 PM
Yeah none have pre made kits I guess I will be contacting arp for pricing
Old 02-18-2016, 05:22 PM
ronjenx's Avatar
Have you looked into what may have caused the head gasket to fail?
The OEM head bolts seem to be holding up fine.
Old 02-18-2016, 05:49 PM
Originally Posted by ronjenx
Have you looked into what may have caused the head gasket to fail? The OEM head bolts seem to be holding up fine.
Too much boost.... Lol it's supercharged 10--13 psi is too much for my 3.8l weather I find stronger bolts or not once I fix it I'm strictly sticking to wheeling the heck out of it and not raping it on the streets anymore.
Old 02-18-2016, 06:00 PM
ronjenx's Avatar
Ah yes! I figured something was up.
A stronger head bolt may require a differently designed head gasket.
And then you have to ask...will the threads in the block take the load of a stronger bolt. (thermal expansion load, that is.)
Old 02-18-2016, 06:33 PM
Ah yes! I figured something was up. A stronger head bolt may require a differently designed head gasket. And then you have to ask...will the threads in the block take the load of a stronger bolt. (thermal expansion load, that is.)
I have no idea one bandaide to another lol can't believe no one else ran into this problem
Old 02-19-2016, 04:24 AM
T&ERun's Avatar
With boosted applications Cometic head gaskets and ARP studs are your best friends. Oh, and tighter valve springs also LOL.
Here is a page from Cometic's site. Cometic Custom Gaskets Says they make custom gaskets. I don't see the 3.8 on their site, but maybe they would make you a set. If so, run those with ARP studs and you'll be golden. Also, with that much boost you may run into valve float problems. You may need to find valve springs that will support that much boost. Maybe the stock one will, I'm not sure.
Old 02-19-2016, 10:03 AM
Former Vendor
TOTL Innovations's Avatar
Prodigy Turbo offered upgraded head studs for their higher boost version if I recall correctly so you probably wont need to get custom studs made.
Quick Reply: Stronger headbolts? 3.8l
