stock x on 35's
Old 09-17-2009 | 04:20 PM
the_cuse420's Avatar
Default stock x on 35's
would 35 be okay on my dana 30 up front and not bend my axles
Old 09-17-2009 | 04:33 PM
northernjosh's Avatar
Some people are doing it but I think its best to make upgrades. Like the gears and driveshafts. I am going with 5.13s and not sure on the driveshafts yet. from what I've read anything around 4.10 and below with 35s is sluggish.
Old 09-17-2009 | 04:43 PM
Yes that is how I learned by searching and the other big thing is how you will use your jeep? a daily driver or off road etc).
Old 09-17-2009 | 04:55 PM
Thanks, I was figuring he must have a lift for 35s and with the lift and 35s is that not a lot of stress on the drive shafts as well?
Old 09-17-2009 | 05:55 PM
nangulator's Avatar
You should beef up the front axle with EVO gussets and sleeves or over time you will spread the outer ends, were the ball joints are located.
Old 09-17-2009 | 06:59 PM
rballman's Avatar
i know upgrading gears helps for more power, but does it help things from not braking the D30?
Old 09-17-2009 | 07:09 PM
nthinuf's Avatar
No, the smaller gear teeth of a lower ratio makes it some percentage weaker. (hence the ongoing debate about going past 4.88's in a D30) How much weaker, I haven't heard any answers to.
But a whole lot of people are running D30's with 5.13's and 35's with no issues. Just drive like you know it's not a D60 and you'll be fine.
Old 09-17-2009 | 07:20 PM
rballman's Avatar
i guess my question is this... having 4.88 would cause things to fail less than keeping 3.21s? i am just curious...i need to read up on gears and teeth size
