Stock Rubicon Tires/Wheels w/3" Lift?
Everything I've read about the 3'' TF is that it's more like a 4-4.25 inch lift..they run tall. I thought the OME was a 2'' that ran more like 3'' if you went with hd springs? Either would be fine with stock wheels, but I'm trying to understand the question cause I thought these lifts where kinda different, or am I wrong? Anyone else wana chime in
I've got an 07 2dr with what worked out to be 3.25" worth of lift and I bought a set of stock rubi shoes and rims for it. I think it looks great, but I am going to get the spacers as well. I am eventually going to go with 33's or 35's, but not till these wear out, as they take me anywhere I need to go.
Too many great options... too few resources.
The lottery deal hasn't really worked out yet, so I'm in the same boat as almost everyone else on this forum... to many wants, and not enough cash.
I'm new to Jeeping... and pretty excited the whole adventure. I'm leaning toward either a 3" Teraflex or a 3" LT OME from Northridge as the first big upgrade. My rig is an 08 JK Rubicon 2-door with an automatic and 4.10s.
My question concerns running the stock Rubicon tires and wheels after the lift kit installation. I'm just curious how many others went with a lift kit and then waited on larger wheels and tires. Will it drive me crazy until I make the move? (I would probably try to force something to happen sooner if it weren't for the fact that I'd like to do the gearing and driveshafts at about the same time as the tires.)
Thanks for sharing any thoughts.
Jeff
Jeff
Here is a pic of my JK after the lift was installed:
Thanks for All Your Great Replies
Hi Everyone,
This really is a great forum, and a great group of posters.
A couple of you are running 1-1/2" spacers. I have read that some people shy away from spacers. Anything that I would need to be concerned about if running spacers? If I don't go with spacers with the stock wheels/tires, what will I be giving up?
Thanks again for all the great input.
Jeff
Jeff
Put 3" of suspension lift on a 2 door and now you're looking at also buying a couple drive shafts with a 2 door automatic transmission ride. Then all the other items that come along with a 3" suspension lift to do it right. Adjustable front upper and lower control arms, brake line extensions, longer rear sway bar links, adjustable front track bar and a rear track bar location bracket. That's barely a budget minded upgrade any more and still running on stock tires.
So a body lift does have it's place and 2" springs along side of it will allow you to eventually run 35s. Draw the path to where you ultimately want to be and find out the path to get there with the least amount of used parts liquidating carnage. There are definitely many paths to follow, but not a whole lot that are any more budget minded than using an inexpensive 1" body lift as part of the solution as opposed to opening up the funnel to more costs that aren't going to be around when you're finished.
I installed OME HD front and standard rear coils, nitro shocks x4 and, JKS adj trackbars this summer on my Rubi with the stock tires and wheels. It looks fine until I sack up and put some large meats in those wheels wells.
