Stock rims with 2.5 TF coil lift
On the Tera 2.5" I ran it for the past 9 months with stock wheels and tires without spacers. Just place the swab bar end link on the indside of the sway barn and you will be fine.
The new longer TF sway bar links go in the rear and the stock rears are moved to the front (or change out with front discos). If you run the stock shorter links they will flip over and turn into a pretzel. The stock rims will probably rub without spacers depending on what size tire you are running.
