stock JKUR 315/75r16 Duratacs
Ok so I am pretty sure I have read enough to feel ok about this but want to ask point blank
I am getting my Rims and Tires tomorrow and need to get home with no lift will I be OK on the street to get home.
2015 JKUHR
1" Front Spacer
16x8.5 rims with 4.5 BS
315/75r16 Duras
4 inch lift is a week away
I will be triming my rocker rail about an inch before and pinch seams look fine I have 4+ inch from the top of the 275/70r17s on it now but I just want to feel better is someone has done it before
Thanks in advance
2015 JKUHR
1" Front Spacer
315/75r16 Duras
Thanks in advance
Ok so I am pretty sure I have read enough to feel ok about this but want to ask point blank I am getting my Rims and Tires tomorrow and need to get home with no lift will I be OK on the street to get home. 2015 JKUHR 1" Front Spacer 16x8.5 rims with 4.5 BS 315/75r16 Duras 4 inch lift is a week away I will be triming my rocker rail about an inch before and pinch seams look fine I have 4+ inch from the top of the 275/70r17s on it now but I just want to feel better is someone has done it before Thanks in advance
Check your turning clearance lock to lock before leaving the place..
Just wanted to confirm what others have said 2015 JKUHR 1" front coil spacer 18/60 springs 16x8.5 rims with 4.5 BS 315/75r16 Duras NO RUB AT ALL lock to lock on the street its no issue now if I flexed it as said it would need some trimming.
Oh I DID have to trim the Rubi HR rails and inch they would have rubbed...thx for the responses I got
Just wanted to confirm what others have said 2015 JKUHR 1" front coil spacer 18/60 springs 16x8.5 rims with 4.5 BS 315/75r16 Duras NO RUB AT ALL lock to lock on the street its no issue now if I flexed it as said it would need some trimming. Oh I DID have to trim the Rubi HR rails and inch they would have rubbed...thx for the responses I got<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=632549"/>
You aren't playing on rocks with duratracs so why all the belly clearance?
looks nice. Can I ask why you are going with a 4" lift with 34" tires? That's a lot of lift! I would not go above 2.5" if I were you. It will look better(my opinion), drive better, cost A LOT less and perform just as good if not better.
1. Im in Arizona LOTS of rocks
2. Its going to be a 3.5 lift not a 4 I know about the same but still (RE kit and from what I have read and asked its not a 4+ kit like some others that say 3.5)
3. Armour and winch to come so it will settle some (Doing full Artec kit)
4. Break over
5. I like the look of a JKU at 3-4
Also doing a High steer to keep the roll center lower for stablity (RHD Drag link with insert have the axle side track bar bracket already sitting here)
But points taken
