stock jk with 37's
So... now that we all came to conclusion that im okay with running 37's and a dana 30 for just pavement till i get everything else, would i be able to run just a 1.25 bl with the 37's with stock front/rear bumpers and flares.
1st set-up
1.25BL stock flares and front/rear bumpers with 37's
2nd set-up
1.25BL cut stock flares and stubby front/rear bumper with 37's
out of 1st and 2nd. which one would work? thanks
1st set-up
2nd set-up
Don't listen to the hype. You will be fine running most 37s on a reinforced D30 off road and on. When people say that a D30 can't handle it, they are referring to hardcore component smashing rock crawling. If you do moderate trails and rocks like 90% of the folks on here, you will be just fine with a D30 and 37s. It's not as weak as people would lead you to believe. Of the thousands out there running 37s on a D30 you find VERY few stories of axle damage. Those that do are wheeling either too aggressively or just smashing into rocks without taking the time to pick their lines.
Don't forget, the folks on here are the most hardcore and elite of JKers, so take the advice given with a big grain of salt.
This is coming from a guy who wheels his D30 with 37s pretty darn hard also with stock gearing and have had ZERO issues
1) The Jeep will be driven on pavement only.
2) Hardcore wheelers may run into problems with a D30 and 37's. Those were estimated to be 10% out of entire Jeep population.
I don't think your experiences fall into the 2 above.
Moreover, if you wheel hard enough or simply go crazy, you can break anything, D30, D44, D60, and so on. But does it mean everyone now needs to run and get a PR44/60? Not at all. Especially for street.
Originally Posted by TheTerminator
You are missing a couple points:
Originally Posted by Dwight_Pollard706
I think we should all get together a bake cookies
I also think your missing something, he is going to run a recentered humvee rim and tire, this setup weights over 65lbs more than a stock rubi setup and up to 75 more than a sport. The extra rotating mass is the problem not the trail, stock parts on the front end are not ment for that kind of unsprung weight
I'm talking merely about the D30, not steering. I would like to see some evidence that suggests D30 cannot take 37's on street (be it humvee rims/tires). So far it's nothing more but rumors and tales. On the other hand, there is enough evidence to suggest that it will work just fine on street, and even for ~90% of wheeling.
Your jeep, do it. I'm not against trying I used to run 35x10.50 bias ply swampers on a sprung over yj with stock d35/d30's I even locked the 35 with a lunchbox locker after I granaded the spider gears on the trail. I spent more time replacing ujoints and bearings than I would like to admit but I had a shoe string budget so that's what I did. I think what saved my shafts was my woefully under geared axles (3.08 )paired with 5speed and carb'd i6 that pumped out maybe 140 hp.
You are running 4.88 gears that are already small on the d30 the new tire combo is going to put a lot of stress on the pinion and ball joints
Like I said run what you have but I think you would be better served selling your 30 while it's still worth something ( before its destroyed) and build something stronger
