Stock or aftermarket TPMS
Hello all
I plan on purchasing a set of 8089 PC rims. My questions are:
1) Is anyone running the factory TPMS valve stems on their aftermarket rims or are you using the plain rubber valve stems?
2) can the stock TPMS valve stems work on these rims? If not would I need to purchase aftermarket ones to have that TPMS feature...
Please advise, thank you..
Pro Comp Xtreme Alloy Series 8089
Part Number: PXA8089-6873
* 16x8, 5 on 5 Bolt Pattern
* Backspace = 4.5 in.
* Hub Centric = No
* Max Load = 2200lbs
* Offset = 0mm
* Finish = Gloss Black
* Hub Centric = No
* Offset = 0mm
Thank you
