Steering Woes
I had a similar issue when I first installed my 35's. Tire shop aired them up to 40psi, dropped them down to 28psi and it made things much better.
I also have a 2012, and found that my toe measurement was way off from the factory. Adjusting that back to within spec and the tire pressure made the biggest difference for my situation.
I haven't ordered my bolt kit yet, and I probably won't. I try to check every aftermarket part for tightness every oil change, so as long as I keep that up I shouldn't need the kit.
I took the Jeep back to the alignment shop, they drove it and said it was definitely unacceptable. I was told he increased the toe in, and now it drives as it should. Heads up to fellow Jeepers; make sure when you get your Jeep aligned (or you do it yourself) you toe it in a little (1/8" I believe)
I run 1/8" of toe-in with 37"s. I set it when I put my lift on. It's simple to check and adjust.
http://project-jk.com/jeep-jk-write-...-end-alignment
