Steering wheell shake-help
Old 05-26-2013, 06:00 PM
jeepwave's Avatar
Originally Posted by jtphoto JK
Speed dependent shakes and shimmies are always related to tire and wheel issues.
Good to know. Thanks
Old 05-27-2013, 06:29 PM
Marmot mb's Avatar
I had the same, i think partially its my rims, or a rim. I did however massively reduce it by having balancing beads installed instead of weights.
I had the shimmy on two sets of tires, my brand new ones were worse than my mostly worn ones.
When i re installed my mostly worn ones at end of winter i had the beads put in. Way way better now
I will be using balance beads from now on in my 35's.
Old 05-27-2013, 06:54 PM
DesolationMania's Avatar
I go with the flow....tire pressure versus balance.
Old 05-27-2013, 07:57 PM
Fester2572's Avatar
Default Steering shake
I had the same issues when I had a full tank of fuel or weight in the back. A new steering stabiliser and a little bit of tow-out stopped it . After 6 months of going insane and not letting anyone else drive it , it hasn't come back for over a year now. Hope this helps.
Old 05-27-2013, 08:05 PM
milazzocade's Avatar
I had the same problem when I got new tires. All it was was too much pressure in the tires. I went from 35psi to 12 psi on my 36's and it doesn't shake at all now.
Old 05-27-2013, 08:34 PM
Kolton10's Avatar
You probably won't get too many miles driving them at 12 psi will you?
Old 05-28-2013, 04:57 AM
Ryan0260's Avatar
I hope you aren't running 12 lbs on the street.
Old 05-28-2013, 05:16 AM
Collyn's Avatar
It could be a bent wheel or a broken/separating belt in a tire. If it is speed dependent, it has something to do with a rotating part. Be it a wheel, tire, axel, shaft, transmission, etc. anything that spins or rotates that is consistent with increases or decreases of speed. Not that I think it IS the problem, but I've had similar issues with a '65 olds 442 and it was the driveshaft. I bet it has to do with a tire.
Sent from the fast lane while driving one handed.
Quick Reply: Steering wheell shake-help
