Steering wheell shake-help
I'm not having death wobble...it's not that violent but here are the symptoms I am having.
-Steering wheel is shaking enough that it shakes my hands. This happens at around 80km/H it goes away if I go faster OR slower. It only seems to happens at an exact speed
Please note that this starting happening right after I got a tire rotation and I swapped my steering stabalizer (my bilstein was pulling left so I now have an OME from aev)
My set up: 3.5" aev north degree lift kit with 35" tires
Any suggestions?
Any suggestions?
when was your last tire rotation and did they do a crossover or front to rear? did they also rebalance?
this is normal if you haven't balanced and rotated your tires in some time. as all others have said, have the balance checked
You guys are all awesome. Looking for my sticky balance on the rims and I didn't seem to locate one on one of the front tires. Gonna call a shop tomorrow to have them balance the tires and hopefully this will be the trick. I have a feeling that's all it is. Haven't balanced them since my last rotation.
