Steering and wheel shake
Hey everyone,
I am currently having an issue where I hit a bump doing 40-50mph and the tires and steering wheel start to shake aggressively. The shake starts small and progresses quickly to the point that I have to step on the breaks. The shaking will correct itself if I brake hard or accelerate hard. I'm not talking about a small vibration either, it is probably a 15 degree in either direction tire wobble.
I have listed all of the front end steering modifications that I have done to help diagnose the issue. Any help or ideas would be greatly appreciated!
ARB OME 4" lift kit
OME adjustable track bar
OME steering stabilizer
Rock Krawler aluminum pro tie rod
Synergy drag link with flip kit and geometry relocation bracket
OME sway bar disconnects
Terraflex 1.25" wheel spacers (because the tie rod needs extra clearance)
Rugged Ridge 17x9 wheels
Goodyear Duratrac 35" tires
Thanks everyone!!!!!!
ARB OME 4" lift kit
If tires are going to shimmy its in that 40-60 range. I have 1 bad tire when run on the front shakes at 40-45 but smooth at highway speeds.
