Steering upgrade suggestions...gnarly death wobble
Old 06-20-2014 | 11:24 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Originally Posted by Maertz
You move the drag link higher up and closer to the frame. You have to make sure on uptravel it now dont hit the frame. Yes you steering geometry will be better at that lift height but if your steering is limiting travel you have some crazy travel or a crazy ass set up that makes no sense.
^^^^^^x2. Forgot bout this. At full compression on passenger side you could hit the frame depending on your bumpstop setup and how much travel your shocks allow. Some people notch the frame but most just get the proper Bumpstops to keep this from happening.
Maertz, is it more of a problem at smaller lifts like 3-3.5" and not so much at higher? Can't remember if I saw that somewhere or not.
Old 06-20-2014 | 11:30 AM
Crampt0n's Avatar
Ok Im getting what you guys are saying now. So where would I be able to figure out what the proper bump stops are that I should be using?
Old 06-20-2014 | 11:35 AM
Crampt0n's Avatar
Or is this something where I have to take measurements my self by slowly articulating until right before it makes contact?
Cheers
Old 06-20-2014 | 11:36 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Originally Posted by Crampt0n
Or is this something where I have to take measurements my self by slowly articulating until right before it makes contact? Cheers
Boom you got it right here. Manufacturers can give recommended but this is the best way really.
Old 06-20-2014 | 11:42 AM
Crampt0n's Avatar
Thank you guys very much you were a tremendous amount of help!!!
I'll post pics of the install and when its complete
Old 06-20-2014 | 11:53 AM
nthinuf's Avatar
If you are looking at Synergy components, you might check out the upper trackbar/sector shaft brace also. Then again, if you are going up to a 6" lift, what size tires are you planning on running, and will you be going to hydro?
And since you are raising the front roll center with the new bracket, be sure to raise the rear if it is not already.
Old 06-20-2014 | 12:12 PM
Crampt0n's Avatar
I will check that out as well. My goal is to prob 37" or 38" KM2's with gas shocks and reservoirs. Raising the roll center... As I said I'm new the whole front end inter-workings what would need to be done/ how do you check the rear?
Old 06-20-2014 | 12:25 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Basically put a raised axle side rear tracbar bracket in. A good bolt on one is teraflex. Easy install and they have them for higher lifts also.
Old 06-20-2014 | 12:52 PM
Maertz's Avatar
Normally on smaller lifts but truly depends on fenders, tire size, and shocks lengths....the higher the lift the larger the tire and shocks (normally) so uptravel becomes the challenge with clearance but with the tons of different ways to build a jeep it will vary.
Old 06-20-2014 | 04:22 PM
D_engel's Avatar
Thats 3.5" too high. Why so much lift for those tires? The 38" KM2's measure about 37", and the 37's are closer to a 35.5" tire. Keep it low so you dont have to worry about swapping so many parts (i.e. long arms, drive shafts)
Quick Reply: Steering upgrade suggestions...gnarly death wobble
