steering stablizer
that's because SS like bilstein, fox or the like are gas charged.
Gas charged, especially the Bilstein will have a slight pull. This is a known issue... That is offset for the most part with heavier tires... If you are running 35's or larger it will all but fully eliminate the "gas charged drift"... Smaller than 35's and you will notice the pull... Usually to the driver side/center stripe. Another way to offset the effect is to run dual stabilizers... But this is usually overkill anyway.
I had to replace the stock the third time I bashed it. Couldn't turn passenger. Borrowed a Procomp for a couple weeks and have been running the JKS for a few months. Can't tell the difference between them. I've heard of problems with gas charged, mostly Bilstens pull to the side. Does the new Fox run straight?
